torque conversion
torque conversion
torque conversion
dear experts..,
please tell me how to convert kips to ft-lb during torquing of structure boltss?
RE: torque conversion
Are you saying you want to know how to calculate what tightening torque you need to use in ft.lb achieve a given nominal bolt preload in 'kips'?
I believe there may be a FAQ in one of the forums that will help you, try searching for bolt torque calculations or similar. Or take a look in the FAQ section of somewhere like forum725: Welding, Bonding & Fastener engineering.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
