How can an (experienced) foreign find work in the US?
I am from Southeast Asia. I came to the US right after highschool and received my bachelor's and master's in Civil/Structural from a university in Illinois, and passed the FE/EIT right after I got my BSc. I then worked for a couple companies in Chicago. In 2009, the company I was working for wasn't (and still not) doing so well, so I was let go. Instead of waiting around for an extended period of time, I decided to go back to my home country to work and do business here. After a while, I realized that I really would rather work in the US instead of here in my home country.
Here are some of my concerns:
1) My line of work differs greatly. My jobs back in the US consisted of mainly consulting work (I provided contractor support for my first job; and designed power plants components in my second job). But my work here mostly deals with the business and marketing side of things (construction/contractor, and also housing residence development). How do companies view differing work fields like this?
2) I got my EIT back in 2002. Back then, as my previous employer was a big company (3000+ engineers+drafters at its peak, and they had 60-ish PE holders for Illinois), I was not required to take PE and hence didn't take it. Would it look bad for me if I have so much time after getting EIT and still not obtaining my PE?
3) I don't have green card/permanent residence and hence I'll need sponsorship. How is the job climate nowadays?
4) I currently live outside of the US. I understand that eventually I'll have fly up there to meet potential employers, but how do I establish contacts from all the way over here?
From these 4 points I am most concerned about numbers 3 and 4, as I can probably explain 1 and 2.
Thanks for reading the wall of text :)
RE: How can an (experienced) foreign find work in the US?
Or talk to old acquaintances/employers
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying ” Damn that was fun!” - Unknown>>
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
When you worked in the US, what was your status? Did you have a green card then? Did you relinquish it when you left the country? Are there any problems associated with your previous residency that would affect gaining permanent residency again?
You may have luck with an international company that has 1 or more US offices.
B+W Engineering and Design
Los Angeles Civil Engineer and Structural Engineer
http://bwengr.com | http://bwstructuralengineer.com | http://bwcivilengineer.com
Richard A. Cornelius, P.E.
WWW.amlinereast.com
