Need help angling plains in solidworks
I'm having a major amount of difficulty getting my plains to angle. I've tried a thousand times to do it how i'm being taught, but its still ending up flat. I have no idea what I'm doing wrong, if anything at all. Can anybody help me out? Thanks
RE: Need help angling plains in solidworks
Jeff Mirisola
My Blog
Select a Plane
Select the Angle option and set the angle
Select an axes, edge, two vertices/end points, or a sketched line
Select the green check mark
Someone here will show you the way. Once you understand the options is is fairly trivial to create any desired workplane.
Can you attach the file here?
