Creo 2.0 solid model leaving tracing lines when its moved or rotated
Greetings my Friends in Pro E World
I have Creo 2.0 when i move the solid model tracing lines or multiple images of the same are apearing following the original model the same as points in sketch and so on.
I have Pro E 4.0 and that problem do not happen on it. The video card that i have its good for Pro E. my Computer its an ASUS.
If any of you would have a solution or suggestion please kindly respond to this question.
Best Regards
Faust
Best Regards
Faust
RE: Creo 2.0 solid model leaving tracing lines when its moved or rotated
Ben Loosli
Drivers may also be an issue and the latest driver may not be certified or even the best for a version of the software. Many times I have installed the prior to latest driver to get an issue resolved.
Ben Loosli
I will look in to the video cards and find out the ones certified.
Thank you.
Best Regards
Faust
