STAAD Analysis VS. Second Order Analysis
Is STAAD Analysis is a Second Order Analysis?
RE: STAAD Analysis VS. Second Order Analysis
Note, Staad 2007 doesn't have small delta effect turned on by default, but I think it does for STAAD.Pro V8i. Try the command PDELTA n ANALYSIS SMALLDELTA, where you replace [n] usually by a number greater than 15. If you need more help on the Staad Pro, it would be helpful to visit http://communities.bentley.com/products/structural...
What are the difference in the design between 2D frame and 3D frame analysis? Does 3D frame is used in actual analysis and design of the structural members? Are the beams will be also be design using the moment from PDelta Analysis?
By the ways thanks again. :)
