hi every body i have a problem wit
hi every body
i have a problem with abaqus,
i model composite laminates using XFEM, but all time get the following error message;
37296 elements have fewer than the required number of integration points. The elements are identified in element set ErrElemMissingIntegPoints.
any one can help me
thank you
best regards
Mohammed
any one can help me
thank you
best regards
Mohammed
RE: hi every body i have a problem wit
The default volume element in Abaqus/CAE 6.12 has the R-ending (example C3D10R) and the R stands for "reduced integration". Change this in your preprocessor or maybe you can just delete the R's in your .inp-file.
Im not sure this will fix it but it might be worth a try.
Best regards,
any one can help me
thank you
best regards
Mohammed
