Journal - Select objects to change layer
Hello Eng-Tips
Attached you will find a journal that move Datums/Curves/Sketch & Sheets to differents layers. The main idea for this journal is to organize any objects in the view. There is an issue I can't find a solution (or a clue at least), after the objects have been move and trying to uncheck the Show/Hide checkbox in "Layer Settings" (Ctrl+L) the objects are still in View; these can be fixed by closing/opening the file but it would be annoying.
BestRegards
RE: Journal - Select objects to change layer
Try the following:
CODE
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Const DatumLayer as Integer = 62
Const CurveLayer as Integer = 42
Const SketchLayer as Integer = 22
Const SheetLayer as Integer = 12
'move datums
for each datumObj as DisplayableObject in workPart.Datums
	if typeof(datumObj) is DatumPlane then
		datumObj.Layer = DatumLayer
		datumObj.RedisplayObject
	end if
next
'move curves
for each curveObj as Curve in workPart.Curves
	curveObj.Layer = CurveLayer
	curveObj.RedisplayObject
next
'move sketches
'do this after moving curves, sketch curves will update to sketch layer
for each sketchObj as Sketch in workPart.Sketches
	sketchObj.Activate(False)
	sketchObj.Layer = SketchLayer
	sketchObj.RedisplayObject
	sketchObj.Deactivate(False, Sketch.UpdateLevel.SketchOnly)
next
'move sheet bodies
for each bodyObj as Body in workPart.Bodies
	if bodyObj.IsSheetBody then
		bodyObj.Layer = SheetLayer
		bodyObj.RedisplayObject
	end if
next
End Sub
End Module
www.nxjournaling.com
Hellos cowski,
Thanks for your response. A few questions, I made some modification to the original code adding some "If Type" sentence to test if the tempObj is Datum Plane, Datum Axis, Datum Point or Datum Coordinate System, all four belong to DatumCollection Class.
I try to declared as such "If TypeOf tempObj Is DatumCOllection Then" and then change the layer but in response I get an error (I found out that layer is not a property of DatumCollection Class); so how could be the code to use DatumCollection to avoid doing four "IF TYPE" check or four "For Each /Next" check as you suggest.
BestRegards
In your code you were looking for datum planes only, so I replicated that in my code. If you want all the datums to move to the same layer you can skip the type check altogether.
CODE
'move datums
	end if
next
This will move all the datum types (plane, axis, point, csys) to the same layer.
However, if you want to separate datum planes to one layer, datum axes to another layer, etc; you'll have to check the type before moving them.
Hi Cowski,
Asper your coding all Sketches, Datums, Curves etc will move in respective Layer. But My question is If I have used 5 sketches in my model, All 5 sketches has to move in different layer like 22,23,24,25 & 26. so, for this how to write coding.
Thanking you.
Cowski,
As ou suggested, I comment only "If Type" and "EndIf" lines and it only works with planes and axis but not with point and csys. I'm trying to move them separately but not luck so far. Attached you
Attached you will find the original code (final version) with some lines added to redisplay the layer (don't work). In this journal csys and point move to the indicated layer.
DavidQ,
I don't see an attachment...
holyghost,
One strategy would be to increment the sketch layer variable each time through the loop:
CODE
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Const SketchLayerStart as Integer = 22
dim i as integer = 0
'move sketches
	sketchObj.Layer = SketchLayer + i
	i += 1
next
End Sub
End Module
A CoordinateSystem and a DatumCsys are two different entities: the DatumCsys is a feature that encapsulates 3 datum planes, 3 datum axes, and a point; the CoordinateSystem is a saved csys, ie the result when you "save" the WCS (Format -> WCS -> Save).
I strongly suggest working with the collections of objects that the Part gives you access to. This has several advantages:
  • it will eliminate the need for many of the If TypeOf... statements
  • it returns both visible and hidden objects
  • you can control the order the types of objects are processed
The last point is especially important because the system does not differentiate between sketch curves and non-sketch curves. If you move a sketch object then later move a curve object that happens to belong to the sketch, it will remain out of sync until the sketch updates (the sketch will belong to one layer and its curves may belong to another).
Looks like that line should read:
CODE -->
sketchObj.Layer = SketchLayerStart + i
Its working fine , But those are not going to under Sketch Category those are going under Curve Category why? How to fix this problem
Quote (holyghost)
There are multiple ways to "fix" it, two of which are:
  • change the "22" in the following line to be the first "sketch" layer in your file (I used 22 because that is the number you mentioned in your original post)
  • edit your layer categories to match
good catch, kfraysur, I didn't test the code before posting it. smile
Yep working
thanks
Hi
Everything is fine, But I fixed 15 layers only for sketchs like 21 to 35. Then how to write that ifany sketchs more than 15 , It should popup that sketch limit is crossed.
Thanks.
Something like this should work:
CODE -->
Const SketchLayerStart as Integer = 21
'Make 'MaxLayer' the last layer you are willing to move a sketch to
Const MaxLayer as Integer = 35
dim j as integer = SketchLayerStart
'move sketches
	If j <= MaxLayer
	     i += 1
             j += 1
        Else
             Msgbox("The maximum sketch layer value of: " & MaxLayer & " has been exceeded)
        End If
next
