Sequence(Automatic) - Structure Manager (Team Center)
In the Assembly Sequencing, is there anyway that the NX can memorize the steps (sequence) of creating the assembly?
For example: If I am adding components into an assembly file with a specific sequence, can I the NX memorize this sequence and use it as an automatic sequence or something like that? Or maybe I can use the constructing sequence to generate -automatically- the structure manager (the Find Number) in the Team Center. Is this possible?
Can adding the parts into the assembly file with a sequence help me in Assembly Sequencing or in Team Center to vreat a break down structure file from the Structure Manager? Any tip would be helpful for me.
Thanks in advance,
MSRE
