NX8.5 and NX8 files
NX8.5 and NX8 files
NX8.5 and NX8 files
Is it possible to open NX8.5 files in NX 8.0?
RE: NX8.5 and NX8 files
The point 5 releases are considered major version changes, therefore you can't open an 8.5 file directly in 8.0.
www.nxjournaling.com
The point 5 releases usually use a different version of the Parasolid kernel, which is what prevents you from opening them in a prior release. The release notes for 8.5 would tell you if this is possible. Or John will see this and reply. ☺
Ben Loosli
