Export data sheets to pdf
Hi, I have 100 process data sheets in intools that I want to save on my computer. i know that I can click one by one and then print and select pdf, but if I have a lot of data sheets this is not the best way to do it, because i sould have to do the same procedure 100 times. I havent found the way to save all 100 data sheet as a pdf document (at the same time), can anyone help me? is there a way to do this?
