Error in text command in UG Drafting
I am facing a error while clicking on "Text" Command in NX 7.5.4.4 MP8
The error is as "error recovery completed for the following error: input is wrong".
Please suggest to fix.
Chandra
RE: Error in text command in UG Drafting
Hi Chandra,
I feel GTAC can give you better support on this. Are you getting the error specifically for TEXT only or any other commands also?
You can test if you can reload your default annotation settings using Preferences/Annotation...LOAD ALL DEFAULTS .This may work for you
Optionally you can try running a PART CLEANUP (File-Utilities)on this particular file.
Still i will recommend contacting GTAC for the same or at least keeping your site admin in loop.(to avoid any inadvertent change in your organisation site standards :))
All the best.
Best Regards
Kapil Sharma
