Half dimension line
Half dimension line
it's possible to obtain the result like the image attached.
Thank you...
Using NX 8 and TC9.1
RE: Half dimension line
you should do change the Style of that specific dimension, and on the Dimensions-tab disable Display Arrow on Side 1 or 2, depending on the selecting sequence.
You should do the same with Display Extension Line on Side 1 or 2.
Hope it is clear...
Best regards,
Pascal,
NX8 and waiting for NX 8.5, on Win7 64 Bit
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
the image was done with the setting you suggest.
Please try if you are able to have this situation.
Thank you...
Best regards,
Michaël.
24.0 GB
Not an exact copy of what you require but in case this is acceptable...please find attached the image herewith.
Best Regards
Kapil Sharma
the UNI-3973 and 3974 standard for drawing say that dimension must stay over the dimension line.
Thank you...
I am unware of any direct method (the reason what i guess is that untill the dimension value breaks the arrow lines into two partition by placing itself in the middle there is no way we can control or treat the dimension arrow and extension seperately into two parts).
But still i managed to get a workaround if seems usable to you.Please find attached an image herewith.
Best Regards
Kapil Sharma
Best Regards
Kapil Sharma
Thank you...
If you right click the dimension and choose STYLE.then in the third tab LETTERING you will find this option ALIGNMENT POSITION.In and all i used an already created expression to fill in the Dimension text value.(Right click dimension/EDIT APPENDED TEXT).Sorry but this is the only thing i can get hold of.
Best Regards
Kapil Sharma
It will initially take some practice, but if you have problems just post them.
thank you to all for the support and suggestions.
Thank you...
