Find (search)word in TXT file - extract line in variable - trim variable from left to filepath star
Hi
Can anyone here explain me , how I can search i a TXT file (VB.net) ,
I know how to open with streamreader and so on , also to write or append to it.
But I need a code to search in file, for example at XTB or ZBTFG1102, and then store the entire line in a variable.
and next trim the variable until filepath start: U:\......
So the variable only contains the filepath.
Can anyone help me ?
lkl
txtfile:
7006.01.008.01 xtb -/20100377 U:\ugi\Arda\ADH-Diverse\Gru7008\gr03\Styr+Bosning\7002.07.001.01_teg.prt
7006.01.004.02 larsklok -/20100347 U:\ugi\Arda\ADH-Diverse\Gru7008\gr03\Styr+Bosning\7005.04.001.01_teg.prt
7006.01.004.01 zbtf1201 -/20111107 U:\ugi\Arda\ADH-Diverse\Gru7008\gr03\Styr+Bosning\7001.04.001.01_teg.prt
7008.03.002.01 ZNNOFGHOQAREGV -/20120301 U:\ugi\ArdA\ADH-Diverse\Gru7008\gr03\Styr+Bosning\7008.03.002.01_teg.prt
7008.03.001.01 ZBTFG1102 /20120307 U:\ugi\Arda\ADH-Diverse\Gru7008\gr03\Styr+Bosning\7008.03.001.01_teg.prt
lkl
txtfile:
RE: Find (search)word in TXT file - extract line in variable - trim variable from left to filepath star
I wrote the below script to step through a csv file and change some expressions:
CODE -->
' NX 6.0.3.6 Option Strict Off Imports System Imports NXOpen Imports System.IO Imports System.Windows.Forms Module NXJournal Sub Main Dim listFile as String 'open csv file Dim fdlg As OpenFileDialog = New OpenFileDialog() fdlg.Title = "Choose the Border CSV file" fdlg.InitialDirectory = "C:\ESS\Border Change" fdlg.Filter = "All files (*.*)|*.*|CSV files (*.csv)|*.csv" fdlg.FilterIndex = 2 fdlg.RestoreDirectory = True If fdlg.ShowDialog() = DialogResult.OK Then listFile = fdlg.FileName End If 'read the list into an array Dim num_list As Long Dim itemID As String Dim itemRev As String Dim tmpstream As StreamReader = File.OpenText(listFile) Dim strlines() As String Dim strline() As String 'Load content of file to strLines array strlines = tmpstream.ReadToEnd().Split(Environment.NewLine) ' Count number of list num_list = UBound(strlines) Dim i As Integer for i = 0 to num_list - 1 strline = strlines(i).Split(",") itemID = strline(1) itemRev = strline(2) ' Thing to do: START Dim theSession As Session = Session.GetSession() Dim lw As ListingWindow = theSession.ListingWindow lw.Open() theSession.ListingWindow.WriteLine("Number of lines: " + num_list.ToString + " Working on: " + i.ToString + " ") theSession.ListingWindow.WriteLine("Opening: " + itemID.ToString + " Rev: " + itemRev + " ") Dim basePart As BasePart Dim partLoadStatus1 As PartLoadStatus basePart = theSession.Parts.OpenBaseDisplay("@DB/" + itemID + "/" + itemRev, partLoadStatus1) Dim workPart As Part = theSession.Parts.Work Dim displayPart As Part = theSession.Parts.Display partLoadStatus1.Dispose() Dim markId5 As Session.UndoMarkId markId5 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Expression") Dim expModified1 As Boolean Dim errorMessages1() As String workPart.Expressions.ImportFromFile("C:\ESS\Border Change\exp_to_change.exp", ExpressionCollection.ImportMode.Replace, expModified1, errorMessages1) Dim nErrs1 As Integer nErrs1 = theSession.UpdateManager.DoUpdate(markId5) Dim partSaveStatus1 As PartSaveStatus partSaveStatus1 = workPart.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.True) theSession = Nothing basePart = Nothing partLoadStatus1 = Nothing workPart = Nothing displayPart = Nothing markId5 = Nothing expModified1 = Nothing errorMessages1 = Nothing nErrs1 = Nothing partSaveStatus1.Dispose() ' Things to do: END lw.WriteLine("Done processing") lw.WriteLine(" ") lw.Close() next End Sub End ModuleThe CVS file looks like:
CODE -->
Adam
thank you for the answer , I´m not sure if I can use it ,but
I will give it a try
lklo
I tryed with this solution - it work´s very well.
attached code = test
I have to use the search function in a menu with blockstyler.
lklo
CODE -->
Option Strict Off Imports System Imports NXOpen Imports System.IO Imports System.Environment 'Imports System.Windows.Forms Imports NXOpen.UI Imports NXOpen.Utilities Imports NXOpen.UF Module NXJournal Sub Main Dim nxs As Session = Session.GetSession()'------------------------------- Dim lw As ListingWindow = nxs.ListingWindow'----------------------------- Dim path As String = "C:\NX_test_dir\G_h_Map_File\G-h_List.txt" Dim sw As StreamWriter '==================================================================================== Dim objFile As StreamReader = File.OpenText(path) dim strLine as string dim hole_line as string dim trim_line_left as string dim trim_line_right as string dim final_path as string dim first_pos as integer dim last_pos as integer dim find_word as string = "Zbtf1" Do While objFile.Peek() >= 0 strLine = objFile.ReadLine() If InStr(1,strLine, find_word,vbTextCompare) Then first_pos =InStr(1,strLine, ":\",vbTextCompare) last_pos =InStr(1,strLine, ".prt",vbTextCompare) hole_line=strLine End If Loop objFile.Close() trim_line_left=mid(hole_line,(first_pos-1)) trim_line_right=left(trim_line_left,(+last_pos-first_pos+6)) final_path=trim_line_right lw.Open()'--------------------------------------------------------------- lw.WriteLine("test Search:>>" & find_word) lw.WriteLine("test Catched strLine:>>" & hole_line) lw.WriteLine("test final_path>>" & final_path) '======================================================================================== End Sub End Module
