Expansion bolt near cut off anchor rod
I have a problem where some anchor rods are located in the wrong spot. Instead of cutting off the base plate and re-welding would it be possible to use an expansion anchor (25mm diameter) 70mm away from the existing anchor rod and cut off the existing rods? The existing the bolts have loads that are 2.25 k tension and .16 k shear. Looking at the Hilti information it gives spacing for both bolts being loaded not just one. Because of the heat epoxy anchors can not be used. Thanks
RE: Expansion bolt near cut off anchor rod
John Southard, M.S., P.E.
http://www.pdhlibrary.com/
