Rectangular Ordinate Dimensioned Drawing
The company I work for does a lot of machining for other companies as well as our own. I came across a drawing last week where there was a front view, right side view and to the right of that the view from the backside. In the front view there was a bore that was dimensioned as 0, 0. The bore was about 2/3 the way down from the top in that view, that is, it was not in the middle of the part vertically in that view. Then in the adjacent view looking in from the right side there were 4 tapped holes (one at each corner). The horizontal (x direction) 0 baseline in this view was shifted up to be at the center of the pattern for the 4 holes. I had always learned that the horizontal 0 baseline should carry across to all adjacent views and not move up or down if they are indeed standard orthographically projected views. Am I off base here in my thinking? If not, can someone point me to a reference that either explains my thinking or refutes it?
Also, that third adjacent view to the right of the right side view actually had the 0 baseline moved back up where it aligned with the front view.
Steve
Steve
RE: Rectangular Ordinate Dimensioned Drawing
Ordinate dimensioning should, as opposed to "shall", be done from a common datum. It sounds like poor drafting.
Do you have a question?
JHG
Actually, I had two questions in my post. Looks like you agree with my thoughts, (first question). For me to convince anyone here that it is wrong, I was hoping to find it spelled out in an industry standard or military standard somewhere. Would you know of any such standard or is it simple as Drafting 101 and everyone should know it?
Steve
Is there any chance that we could see the print? At the moment I am leaning towards drawoh's opinion that there is an error on the drawing, but seeing the print would help.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
I smell that initial description did not provide all important details.
I don't think I can provide a sample, unless I draw something similar, or water down what I have to make it unrecognizeable. How would I put a sample on this forum. I've not done anything like that on this forum before.
Steve
I think PDF, PNG, JPEG, DOC, PPT formats of files are preferred by most of us here.
Actually, dimensioning from more than one datum makes perfect sense to me. There are circumstances where you might want to do it. I can interpret it as per ASME Y14.5M.
It might not mean what the drafter thinks it does. GD&T is a language, not a procedure.
A good exercise with a marginal drawing is to take everything seriously, and ask yourself how you would inspect the part. What sort of part would you accept?
JHG
I've uploaded a sample .png file to "Engineering.com" called "Ordinate Dimensioning Sample". Have a look. I did have to remove a lot of lines and dimensions for proprietary reasons.
Steve
Unless certain features are clearly identified as datums, and dimensions on your example are shown as basic, there are no special rules in the standard about your baselines being associated with one single point thru the entire drawing.
Dimensioning you use is known as Rectangular Coordinate Dimensioning Without Dimension Lines, and it is treated like any other dimension, only “without dimension lines”
You mention that there is “very little” GD&T used on the drawing. Is any of it associated with the features you use in your example?
The drawing is poor, but not because of the origin moving up and down depending on the view. It is rather because there is no clear identification as to which features are datum features, which features are related to which datum features and that the dimensions locating 4 holes are not basic.
Your idea of having the origin in the same place is based on assumption that each and every feature in center view is located from the hole in left view (or maybe from the triangle in right view, who knows?). But what if the intent is to locate the pattern of 4 holes from the biggest hole? Would it really be reasonable to use the same origin as in left view for this purpose?
I asked about this a while ago.
thread1103-261904: Plus Minus Tolerances
The attachment is not there any more. It was a rectangular plate with some holes in it. All dimensions are plus minus dimensions from one edge, and there were no datums or GD&T. There was no satisfactory answer to my question.
If the second edge is marginally within the angular tolerances, do I measure from the edge, or to I (arbitrarily) select the primary edge for orientation, and measure from the furthest point on the second edge?
JHG
Essentially, no GD&T means no answer to your question, exactly because drawing can have different interpretations.
WITH GD&T you take your measurements from something as close as possible to perfect datum planes, A.K.A. “datum simulators” – you know the drill.
Nice picture included
JHG
The fact that there is no answer to your question is the reason they invented GD&T in the first place.
