Lap splices for #14 rebars
ACI 318-11, section 12.14.2.1 does not permit lap splices for bars larger than #11. The commentary says it's because of lack of experimental data on lap splices for #14 and #18 bars.
We are designing a pile supported mat, 5'-6" thick with a clear cover of 9" to the bottom bars.
Are splices for #14 bars permitted by other (country) codes in situations where clear cover to rebars is in the range of 8" to 9"?
RE: Lap splices for #14 rebars
and therefore a clear cover of 9".
And for positive bending you typically like to have the bottom bars extend far enough to be effective in tension due to mat arching action (deep beam theory).
I have attached a file showing calculations for development length for #14 rebar for the project. The edge of the mat from the centre line of piles is 4'-0" minimum. Although the sketch shows overlaps @ 12" o.c., alternate bars could be spliced, thus increasing the c/c distance of the bars being developed to 24" o.c. (staggering of splices)
The bars are being developed on either side of a given section. The overlap shall be 2 * development length = 2 * 38" = 76" = 6'-4". It does not seem to be too large theoretically.
ACI 318 -05, R7.6.6.4 - Bundling of bars - Commentary : A limitation that bars larger than #11 not be bundled in beams or girders is a practical limit for application to building size members. The Standard Specifications for Highway Bridges permits two-bar bundles for #14 and #18 bars in bridge girders. I am not familiar with bridge design. Does the standard cited above permit bundling of #14 rebars using splices?
Thank you all once again.
If I got paid for every hour I worked, I'd be a wealthy man.
