CFD and cylinderhead design
Does anyone recomend a SAE book or paper that shows how CFD can be used to aid in cylinder head design?
RE: CFD and cylinderhead design
victorymotorsports,
A search on SAE International's website (www.sae.org) produced the following results using the keywords:
CFD cylinder head design
WebPage: Off-Highway Engineering Online: Technical Innovations
www.sae.org/ohmag/techinnovations_12-99/01.htm
WebPage: Automotive Engineering International Online: Tech Briefs (March 2002)
www.sae.org/automag/techbriefs/03-2002/index.htm    ;
Paper: 1999-01-1183: A Comparison of Experimental and Analytical Steady-State Intake Port Flow Data Using Digital Physics
Paper: 1999-01-0170: Direct Injection Gasoline Engines - Combustion and Design
Paper: 2000-01-0570: On the Flow Modeling Through the Valve Assembly in Engine Cycle Simulations
Paper: 2000-01-1179: Numerical Study of the Combustion Chamber Shape for Common-Rail H.S.D.I. Diesel Engines
Also, try searching on Google.com with the same keywords:
www.google.com/search?sourceid=navclient&q=CFD+cylinder+head+design
Additionally, try adding "SAE" for, perhaps, more specific results.
Best regards,
Matthew Ian Loew
