How to etch steel plate with common products?
I am working on a welding procedure and the welding expert said that we should prepare the test plates with the "Grain" of plate a certain direction.
One of the testing labs I work with told me to use a solution of HNO3 and 98% Ethanol but finding small amount required is becoming complicated.
Does any know of any products that I can get at the hardware or grocery store that can etch the steel enough to determine the direction the plate was rolled?
Best regards, David
Best regards, David
RE: How to etch steel plate with common products?
TTFN
Tap-out chemical remover for removing broken taps is essentially Nitric acid.
It is available in small quantities, but it is not cheap.
B.E.
I could get a liter with a note on company letter head for the most part, good looks just doesn't go as far as it used to, but all I need as about 2mL.
Any way the materials lab is sending one of their guys out next week so I'm covered.
Thanks to all for you time.
Best regards, David
Hope this helps,
