Cable Attenuation - CrossTalk
dear all,
I have a little question about cable attenuation.
It is required in a cable an attenation (relevant to Crosstalk) value max of -55dB. If it is offered a cable with attenuation max 50dB, does the value offerde is acceptable??
thanx all
thanx all
RE: Cable Attenuation - CrossTalk
Second, this cable has to be stranded pairs –as Cat 6?-and it is about ACR of -55Db for 1MHz?
If you would be more specific, I think you could get an answer
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
