Force / Torque Release Pivot
Hi all,
I'm currently designing a system where by the following would be very useful:
A pivot which remains in a "locked" position until a torque setting is over come, releasing the lock allowing the pivot to move freely. (See attached image).
Has anyone come across anything like this before? Any potential leads would be appreciated!
Joe.
RE: Force / Torque Release Pivot
A spring loaded ball detent?
Brilliant idea I'll consider that! I was thinking last night and the system could also be made to work with a similar linear style of device. Like a small spring with a blow-off valve which remains rigid until a certain force is applied. Is anyone aware of any standard components which may be suitable?
Joe.
