Fluid dynamic question?
I would like to ask a few questions about fluid pressure dynamics.
In a closed system, would a higher altitude increase or decrease the pressure of the fluid in the system?
If you had 2 different systems of fluid at the higher elevation how would the density of the fluid affect the pressure change?
In case you are wondering. The systems that I am referring too are in your body. One system would be the blood system and blood pressure, the other system is the CSF (cerebrial spinal fluid) system which surrounds the spine and the brain.
Thanks for any input all of you may have.
Working on a medical problem.
RE: Fluid dynamic question?
