Picture added to a sheet format
I've got an old drawing with a sketch picture added to a sheet format. Now I need to move that picture to a sheet. When I double click on it to activate and "CTRL+C", and then try to paste it on a sheet, SW copies entire sheet. I cannot even delete that picture. Picture manager allows to resize or rotate a picture, but not to copy it.
Any suggestions?
Thank you,
Boris.
Any suggestions?
Thank you,
Boris.
RE: Picture added to a sheet format
RMB on the sheet and select Edit Sheet Format to see if you can then click on the image.
- - -Updraft
I'll try duplicating the setup and solution to your problem with my own example to see if I get the same issue.
Michael
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
