Macro to know the type of document in the complete catia tree
Here is an interesting code that give the type of all documents in a tree. You could know if it is a part, a product, or a component. It could be very useful in order to introduce some userrefproperties or other thing in different type of file. Some code are used from other codes find on the web.
CODE --> VBA
'By e. perichon , some code borrowed from forums
Sub CATMain()
    GetNextNode CATIA.ActiveDocument.Product
End Sub
Sub GetNextNode(oCurrentProduct As Product)
    Dim oCurrentTreeNode As Product
    Dim StrNomenclature, StrDesignation, StrWindows As String
    Dim i As Integer
    ' Loop through every tree node for the current product
    For i = 1 To oCurrentProduct.Products.Count
        Set oCurrentTreeNode = oCurrentProduct.Products.Item(i)
        ' Determine if the current node is a part, product or component
        If Right(StrWindows, 4) = "Part" Then
            'MsgBox oCurrentTreeNode.PartNumber & " is a part"
        ElseIf IsProduct(oCurrentTreeNode) = True Then
            'MsgBox oCurrentTreeNode.PartNumber & " is a product"
        Else
           'MsgBox oCurrentTreeNode.PartNumber & " is a component"
        End If
        ' if sub-nodes exist below the current tree node, call the sub recursively
        If oCurrentTreeNode.Products.Count > 0 Then
            GetNextNode oCurrentTreeNode
        End If
   Next
End Sub
Function IsProduct(objCurrentProduct As Product) As Boolean
    Dim oTestProduct As ProductDocument
    Set oTestProduct = Nothing
    On Error Resume Next
        Set oTestProduct = CATIA.Documents.Item(objCurrentProduct.PartNumber & ".CATProduct")
        'Set oTestProduct = CATIA.Documents.Item(objCurrentProduct.ReferenceProduct.Parent.Name & ".CATProduct")
        If Not oTestProduct Is Nothing Then
            IsProduct = True
        Else
            IsProduct = False
        End If
End Function
RE: Macro to know the type of document in the complete catia tree
Sorry i have forgotten the red line that are importants...
CODE --> vba
Sub CATMain()
End Sub
    Dim i As Integer
    StrWindows = oCurrentTreeNode.ReferenceProduct.Parent.FullName
        Else
        End If
        End If
   Next
End Sub
            IsProduct = True
        Else
            IsProduct = False
        End If
End Function
Hi eperichon,
What if I want to compile the output (list) to an existing file in my folder and expand the output (list) as the code runs through the entire tree? Where can I insert a chunk of code for this purpose?
By the way, this has helped me a lot...didn't know I can call out a sub () within itself.
Thanks for the code. I am looking to do something similar where I need to get the number of unique parts for each sub-assembly. Any ideas?
