PMI assembly section view error
thread561-307158: Partial Section Cut in Assembly
Hi
In my nx 5 i used this tool and it worked great, but now in my nx 7.554, when i go through all the same operations, set up a sketch on a plane and so on. once i select the components that i want to be partiality sectioned i get a error saying "a section view target solid is in the wrong part" I'm working in my top level assembly and want it to cut it through the components.
Axis
RE: PMI assembly section view error
Small quick update.
It will work if i try to only section 1 component but if i select 2 or more I receive the same error again.
