sight gauge oil level switch
I am looking for a sensor to mount on a vented oil level sight gauge so that I may visually see the oil level and sense when it goes low (and maybe another one for high). Sensor could be a proximity type or an optical type. Most level switches are designed to be in a fixed location, and you can't see the oil level. Lube Devices has the sight gauges, and many others make float switches. Due to space problems, most float switches will not work. I'd love a sensor that just straps onto the existing sight gauge, but I am willing to replace it if necessary.
Thanks.
Thanks.
RE: sight gauge oil level switch
Not too familiar with manufacturers, but here's a link to a company that sells such items. Hope it helps.
http://www.memecosales.com/
http://kenco-eng.com/product-info/keselectric-oil-...
adjustable level:
http://www.fwmurphy.co.uk/products/fluid_level/flu...
(There are also derivatives that include a valve to automatically top up the oil level from a drum.)
They're probably both more bulky than you would like.
You probably want something more like this:
http://www.alliedelec.com/search/productdetail.asp...
or this:
http://www.stedham.com/sightglass.htm
Mike Halloran
Pembroke Pines, FL, USA
ISZ
