NFPA 30 Insulation requirements
I have to design a 45 000L of Ethanol (95% alcohol) tank,to be installed outside,
for sunny days, we have to insulate the tank.
What is the requirement of the insulation ?, I have checked NFPA30.
Thanks for your help.
Laurent.
Laurent.
RE: NFPA 30 Insulation requirements
Fahrenheit (Btu/hr/ft2/°F) when the outer insulation jacket or cover is at a temperature of 904°C
(1660°F) and when the mean temperature of the insulation is 538°C (1000°F).
You did not see this?
thanks.
Laurent.
Doing a serach of NFPA 30 does not seem to indicate it
