how to connect a solid to a shell surface? not to the edge?
how to connect a solid to a shell surface? not to the edge?how to connect a solid to a shell surface? not to the edge?(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: how to connect a solid to a shell surface? not to the edge?
1.You could just merge nodes, but that would be connecting edge of a shell part with solid part.
2.Standard practice is to embed two rows of shell elements into the solid, a) either by giving very small thickness or b) same thickness.
3.If there is a weld or other kind of connection then you can always use some kind of connector definition to represent that.
why not split the surface into two (along the edge you want to join to) ?
I have a question about (1) :in abaqus is it possible to merge nodes on two parts
another question about (2) : If shell and solid have different thickness, can I do this?
Rb1957
I want to connect a shell surface to a cylinder. I have tried to use shell to solid even though it give good results but I want to use another way to prove it is right.
this is easily done by having coincident nodes and then merging these nodes (so there is only one node on both pieces).
alternatively you can have conincident nodes and attach the two pieces using zero length springs (in NASTRAN its a CELAS or a CBUSH, there should be a comparable element in ANSYS). this way you can control how the two pieces interact (a full welded joints or maybe a pinned joint (forces only) or maybe only some forces (in-plane ?).
i'd be surprised if ANSYS doesn't allow you to intersect a cyclinder with a shell ... it'll be a ridiculous amount of work to do the intersection by hand ??
I am doing this welding in abaqus, I will try to read the manual about the coincident node as you advised.
