Forming a perforated sheet
Someone asked me an interesting question which I did not have an answer for. So naturally, I figured I would ask you guys (and gals).
We take a piece of perforated sheet metal (.149in holes on .1875in spacing), and draw it into a round shape. So the question is there an easy way to model this so that each of the perforations are (relativly) close to where one would expect them to be after the part is formed?
The attached image shows the cross section of the formed part.
Chris T.
Project Design Analyst
Kohler Co. Engine Division
Using NX7.5
RE: Forming a perforated sheet
Are you sure that this is the correct image?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I'm sure. Our current model was created by sketching that profile and revolving it. The attached image was just a cross section through the revolved part.
Chris T.
Using NX7.5
If I am understanding your question correctly you could model the round shape and then create the perforations in a sketch and as long as they are in some sort of pattern you could quickly pattern them and have what you want
Sam Slivinski
Using NX 6
Manufacturing/Aerospace
In a nutshell, yes. Where the model is somewhat flat, it isn't much of an issue to just sketch a few of the perforations, extrude and subtract, and using patterns to finish it off.
Where my co-worker is struggling is how to model the perforations on the vertical drawn sections without much effort.
Chris T.
Using NX7.5
I still am not getting what it is that you're attempting to model. Could you provide at least an image of what the actual part looks like, and if possible, some idea of what the 'perferations' look like? if you're asking what I suspect that you are, you'll probably have to wait until you upgrade to NX 8.5 before you will be able to do this in a reasonable way.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
On second thought, if the metal is being deformed in TWO directions, the potential NX 8.5 approach probably won't help much.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Do the perforations need to be modeled? If you were molding the part, I could see the need for the model to drive the tooling definition; but since you are forming a perforated sheet, wouldn't you just need the finished shape? Is the modeling of the perforations being done just for a visualization, or is there more to it?
www.nxjournaling.com
Modeling the perforations could also be required for FEA and visualization reasons.
Basic weight of the part can be manipulated in the file.
Ben Loosli
Forming the part will have no effect on it's weight. All you need to do is figure out what the pre-deformed blank looks like and the weight can easily be determined. The only thing that a perforated 'before & after' results will useful for FEA purposes since the perforations will most likely have on impact on the behavior of the metal during deformation and of course could also help to determine what the appearance of the final part would look like if that appearance was critical for aesthetic reasons.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Is there an easy way to model this so that each of the perforations are (relativly) close to where one would expect them to be after the part is formed?
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
If you make a sketch and wrap it around the already formed part you will know exactly where they are.
Sam Slivinski
Using NX 6
Sorry it's taken me so long to respond, I got tied up with other things.
Typically, we don't even bother to attempt to model the perforations. From a design standpoint, there really isn't any value in it.
The reason this question is being asked is because of a couple of reasons that others have pointed out. This part is a rotating screen that is at the inlet of the cooling system on a air cooled engine. The purpose of the screen is to block as much debris as possible, but still let as much air pass through as possible.
Our people that handle the analysis of the cooling system performance would prefer if the perforations were in the model. As it is now, they guess the locations. For their purposes, I'm not entirely sure how critical it is for them to have each perforation at it's exact location.
Also, our people that create the service literature from our models have been asking for more realistic models for some time.
Is it a show-stopper if we can't do this? Nah, not really. It would be nice, but I suspect that if it was possible, the model would become quite large and take up quite a bit of computer resources to handle.
Attached is a picture of a similar part.
Chris T.
Using NX7.5
In my experience with smaller perforations through a slightly larger, thicker composite panel (1/2"), NX bogged down very quickly.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
Can you provide more details ?
( possibly a sample of the perforated sheet and a sample of the shape to follow )
I did a quick and dirty test to see if the Global Shaping feature could do it , and it seems quite promising, See attached image. ( Note that i started with a square perforated sheet which was larger than the shape i wrapped to, i have not tried to wrap a solid in this case.)
The Global Shaping is probably in the "NX_Freeform_2" license which not everybody has.
I can later upload the model, if interest exists. ( This one NX 8.5)
Tomas
I'm currently trying to model up a perforated sheet, but my computer is struggling with it at the moment [sadt
I haven't had the need to mess around with Global Shaping much, so I will have to take a look at it. I'd like to take a look at your model, but I'm on NX7.5 at the moment...
Chris T.
Using NX7.5
Hm, probably the Meta Form Feature is the more proper tool for this operation. It should be able to bend the perforated sheet onto a die. The Global shaping might produce something which looks correct but isn't.
I will play around with the model i have and see what i can come up with.
Tomas
I haven;t done any sheet metal design in NX yet, but in SolidWorks I would draw a perforated sheet then bend it. It would then represent the part as it would be if you did it for real
You can do the same thing with NX Sheet Metal as long as the bends are 'Straight-Brake'. It's the curved bends which are preventing this from being a trivial task.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hmmm, Meta Form looks promising...the bad thing is my computer must know that today is Friday, because it seems like it decided to cut out of work early todaydazed
Looks like I will try to tackle this next week!
Chris T.
Using NX7.5
I have experimented a little with the metaform. It seems to do it.
It is a bit "volatile", if one sets the wrong input, it calculates "for ever".
The single sheet body in the image took a few minutes to calculate. ( Didn't clock it.)
Probably one can learn what to do and don't. In this case the shape that i formed to is a single b-surface sheet.
Don't know if this is better or worse.
Attached a 7.5 parasolid copy. ( model made in 8.5)
Tomas
That is exactly what I was looking for!
I've noticed that as well...if the wrong inputs are selected, it basically sits there forever. I'll keep playing around with it to see if I can get something that works
Chris T.
Using NX7.5
Btw, i noted that the option "delete holes"option will only ignore the holes when calculating, it still produces an output with holes. The calculation time for this piece goes "logarithmic" if it is not-selected.
Tomas
Thanks for the tip, that must have been my problem! When I create the metaform feature, the only thing that I see is a bunch of splines that are projected onto the target face. Is this correct, or should I be expecting a surface as the result?
Chris T.
Using NX7.5
What you should see while computing is a Finite Element Mesh that stepwise moves from the "flat state" over to the wrapped state, when that is done NX will create a new surface/ curve etc that has a matching deformation. See attached image of "early" screenshot.
Regards Tomas
As a rough guide to reduce the time it takes to calculate/process the metaform, get as rough idea of the over all size of the part then in under settings --> tolerance --> Linear, enter rougly 25% - 33% of the over all size (if the part is roughly 1000mm max size, enter 250mm or 350mm as your linear tolerance), you can then reduce this after each pass until there is no marked improvment in the preview.
Best regards
Simon NX 7.5.4.4 MP8 and NX 8.5 (native) - TC 8 www.jcb.com
