Eccentricity load application
Dear collages from forum,
I have a question: is it possible to apply a eccentricity in the application of a puntual load? I send in attach a picture of the problem: it is a portal, and puntual loads have to be applied in the crane runway line.
Thank you very much.
https://dl.dropbox.com/u/8161370/Crane_Load.PNG
Juan José
Juan José
RE: Eccentricity load application
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
The method that you say, I didn´'t like to do because it is necessary to modify the geometrie and the loads when changes are performed. I have designed the column under the runway line and then I have apply a constrain with the upper columns. Results are identical. Thank you very much anyway.
Juan José
jJ
Anyway I prefer using replicate option instead, because you can choose which assignments to copy.
