making a loop to go over every time step
I am trying to write a script to save maximum strain progression over entire model.
The problem- I cannot find a command to move between time steps.
It is fine to extract data of one point as a function of time. However, I am trying to search maximum value over entire model each time step, as it's location changes.
I am missing something, or is there any trick to solve this issue?
Thank you in advance,
Andrus
RE: making a loop to go over every time step
SET,,,,,TIME
I think this is what you are looking for.
Exactly what I was searching for, thank you a lot!
