Tolerance from the beam to joint
Dear Sir,
Can you help me in this matter, what should be the tolerance from the beam to the weld joint. A joint should not rest on the beam. In my case the joint weld toe and the beam end is at the same line, hardly say 1mm or .5mm.
what should be the clearance between the beam and the weld joint. Is there any code that can help me.
Waiting for your response
Thanks and regards
Jacob
Thanks and regards
Jacob
RE: Tolerance from the beam to joint
Independent events are seldomly independent.
thread378-337552: Rest Support
where we were just discussing this very subject, and perhaps a good method to avoid it.
Thanks for your valued information.
regards
Jacob
