Periodic time for empty tank for seismic analysis
API 650 gives equations for the periodic times for the impulsive and convective components of a liquid filled tank as the tank is not the governing component. However API 650 does not give the equations for an empty tank. Does anyone know where equations may be found for this case. Example outer tank of a single containment tank?
RE: Periodic time for empty tank for seismic analysis
