How to determine hole diameter in an oil jet? (For bearing lubrication)
Hi guys,
I'm trying to work out the size hole I will need to put into a small oil jet to lubricate a bearing correctly.
I know the pressure of the flow and the flow rate needed.
Is there a "flow through an orifice" type formula I can use to figure this out?
[Metric units would be awesome if possible!]
Steve
Steve
RE: How to determine hole diameter in an oil jet? (For bearing lubrication)
Use SI units throughout
Q = flow in m³/sec
Cv = flow coefficient - use 0.8 for a typical drilled orifice
D = orifice diameter in metres
P = differential pressure across the orifice in N/m²
rho = fluid density in kg/m³
Thanks again
Steve
Good luck
