Beam thermal mechanical analysis
Hello
Does anyone know how to obtain a beam (wire) with a linear distribution of temperature over the cross-section and analyze it statically?
Thank you
Bothul
RE: Beam thermal mechanical analysis
Hi
I wouldnt say you can do just with a wire, since it seems the transversal directions have some importance in your analysis, so therefore I would suggest you to do it with 3d elements. But would be nice if you find the way to use the wire.
good luck
Thank you n3l3
I hope I will
