Process Equipment Anchor Bolting Torque
I want to know which is the torque value to be applied on the base anchor bolts of pressure vessels, process columns and stacks.
Can I simply use the torque values determined for bolts considering bolt diameter and material?
Some say the correct practice is tightening the nut by hand until it locks, then tighten it a quarter of round by tool (nut wrench), put on it a lock-nut and tight it by tool again. Is it correct?
Isn't this harmful to the concrete and grouting?
Is there any standard mention about anchor bolting torquing?
Thanks!
LPC1
Thanks!
LPC1
RE: Process Equipment Anchor Bolting Torque
You need to consider the pullout force of the bolt from the concrete.
I given a link to a typical Hilti fastener with a given grouting/concrete system, if you read through it, it will give you some idea for what you are trying to do
http://www.hilti.co.uk/fstore/holuk/techlib/docs/H...
For instance, for a 3/4" dia HIT-HY 150 MAX with threaded rod.... Tmax = 100 ft-lbs.
http://www.us.hilti.com/fstore/holus/techlib/docs/...
Note that they will lower this at close edge distances (see the tech guide)
ZCP
www.phoenix-engineer.com
Our facility typically has 20-55 year old attachment materials which typically requires NEW foundations or increasing the number, size or type of fastener to secure properly. 1950's concrete and steel in my experience is typically 1/2-2/3 the strength of material today. Possibly 2 different diameter studs could be used?
Rich
