Motion Analysis
Motion Analysis
I'm currently using motion analysis to workout the required torque to rotate a part, but I've run into a problem. The motion analysis settings for the units of torque are N.m, how do I change this to mN.m?
Is there also a way to get the torque values without using a graph, just the actual values?
Muon.
Muon.
RE: Motion Analysis
Hopefully someone will help.
RE: Motion Analysis
RE: Motion Analysis
Didn't realize that N.m could be changed to mN.m in document properties - units.
