find out toolpath type
I would like to show in my program sheet the type of the toolpath.
How can I check that it is 3axis, 3+2 or simoultaneous 5 axis path?
I found a variable, mom_tool_axis_type in a default sinumerik post
but there are values like 0, 1, 3, 19 etc.
Could anybody please help?
kukelyk
RE: find out toolpath type
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6 & NX7.5
but if I have a Z-level profile operation, the mom_operation type is Z-Level Milling. If I have a local coordinate-system, then the tool-axis IJK vector is not 0,0,1 in the main csys. And if I use tilt tool axis on this toolpath, it is the same. My doc postprocessor could watch, if there is a local csys, and the changing of the IJK vector.
So the operation_type is not enough information..
And furthermore there can be 3+2 operations with or without local MCS too..
kukelyk
kukelyk
We added this for cases like this, such as tilting the tool axis of a fixed axis operation, which results in a variable axis path.
Mark Rief
Product Manager
Siemens PLM
When the toolpath is a Point-to-point type operation in a tilted local CSYS, that's not a variable axis path, as the tool axis not varies along the path. Really, it need a 4 or 5 axis machine..
Could I differentiate the paths with 'variable-axis'?
kukelyk
