Case Hardening and Carbon Content
Hi all,
I recently sent out samples of a competitors product to determine their material by ICP-AES. I was assuming that it was most likely AISI 1018 to 1024, but I was surprised when the results came back showing AISI 1026-1029. When the samples were sent out, the test agency was never told that these parts were carburized, and it's possible that a part of the case could have been tested with the sample. These parts are 0.186" in diamter with an effective case depth of 0.004-0.009". Personally speaking, I think that this could have skewed the carbon content higher on the test results. Anyone agree, or is the sequestered carbon from carburizing too small to explain this difference?
RE: Case Hardening and Carbon Content
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
Maui
www.EngineeringMetallurgy.com
