Coolant pressure inside engine
It begun when a friend started talking about replacing the stock water pump by an electrical aftermarket pump on his CA18DET engine.
One of the elements in the manufacturers installation guidelines struck me: remove the thermostat.
This brought me to think about what happens inside this liquid system.
In the case of this engine, and I think for most production car engines, the path of the cooling circuit is: pump – engine block – cylinder head – thermostat – radiator – pump.
The thermostat is open when the engine is at normal working temperature.
How much its valve is lifted from its seat depends on the design and the momentary situation. Obviously this will be different at idle or when racing, when freezing outside or in hot weather.
I gathered some figures from a couple of random service manuals and I found values of 8-12mm when heating it in a pot of water.
It is not hard to imagine that the thermostat being open only that little will cause a flow restriction in the coolant path.
Many literature mention the pressure generated inside the engine and the head because the pump is pushing its liquid against the restriction caused by the thermostat.
This pressure is supposed to be beneficial because it further rises the boiling temperature of the coolant.
Especially inside the head, where the coolant runs sometimes very close to the hot exhaust gas, only separated from it by less than a centimetre aluminium wall.
As I didn't find real-life values of this pressure, I decided to measure it myself while I already planned to measure some other engine parameters.
I took advantage of the threaded hole for the dashboard gauge temperature sender in the thermostat housing to plumb-in a pressure transducer.
Link to the graph
The signal was logged and plotted against RPM.
As you can see, pressure went well over 4 bar.
Mind you, this was at around 5°C ambient. When the weather is hot, the thermostat will open further to achieve the same coolant temperature.
When the thermostat opens further, the pressure generated by the pump will decrease.
Also, this is a fairly high-revving, high hp/cc engine.
Anyhow, this 4bar is a rather high value and I must say that it surprised me.
Installing an electric waterpump and removing the thermostat, you lose this advantage completely.
I was under the impression that nowadays some cars are OEM equipped with electric waterpumps.
Am I wrong and are these just secondary pumps for accessories circuits like heating or turbo core?
Or is the pressure that I measured not really necessary and to be considered completely as parasitic in terms of power consumption?
Or are these primary electric water pumps (if they really exist) fitted to low power engines with a much better thermal design of the internals of the cylinder head casting?
After all the CA18DET was a design from the eighties.
Also worth noticing is that the curve is not flattening off at high revs. Am I right to assume that the pump is not (yet) cavitating?
I would appreciate to know your professional opinions about this.
Thank you for sharing your knowledge.
Jean
Link to the graph
Jean
When we all think alike, no one thinks very much. ---Walter Lippmann
RE: Coolant pressure inside engine
My $.02
An electric pump with no fancy controls will work at one RPM only, just one point on that same curve, and probably not a high RPM, so you wouldn't see 4 bar there. The electric pump is more efficient, when and to the extent that the mechanical pump is spinning faster than it needs to in order to meet the engine's needs.
Drag racers use electric pumps to save weight, and to save that excess power needed to run the mechanical pump at higher speeds. They are also relying on the thermal inertia of the block and the coolant, so the electric pumps sold for drag racing might or might not be large enough to cool the same engine on the street.
I'm not aware of any street cars with an OEM electric pump, but I don't keep up with that stuff like I used to.
Mike Halloran
Pembroke Pines, FL, USA
http://www.daviescraig.com.au/Electric_Water_Pumps...
As they are controlled by a switch sensitive to coolant temperature there is no need for an additional thermostat.
If the thermostat does offer substantial resistance to flow to the extent that it builds that much pressure before the pump flow stalls, then there would be a substantial drop in pressure at the suction side of the thermostat, likely inducing cavitation at the pump if the temperature where above moderate, but then the thermostat would be opening anyway.
I think your over thinking this. Just fit according to the manufacturers recommendation.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Is it variable speed, or just on-off?
At least the thermostat is an analog device, doesn't just slam open and closed.
Jay Maechtlen
http://www.laserpubs.com/techcomm
With the electric pump comes the ability to control temperature via total system flow instead switching the radiator in and out of circuit, so if operated by the pump manufacturers controller it will run at a low rate when the engine is cold and speed up when warm/hot so in theory it will only flow what is necessary to get the cooling needed. This is why the thermostat is no longer needed. I imagine that the placement of its temperature probe is fairly important.
As a pump engineer I have a problem with your pressure figures as I just cannot see a small diameter centrifugal pump generating 4 Bar differential or anything near that. I suspect the decimal point is displaced and the true figure is more like 4m (0.4 bar).
The system pressure should be a function of system temperature and not the pump flow. Ultimately it is controlled by the pressure cap on the header tank, which I'm quite sure will release at considerably less than 4 Bar. Probably more like 1.5 - 2 Bar.
I do agree with your comment that the steadily increasing pressure shows that the pump has not reached cavitation point. That could change when the coolant heats up though; one reason why the system is run under pressure is to delay the cavitation onset and is in fact why a faulty pressure cap can cause overheating, especially at higher rpm.
As Pat says, if you fit according to the manufacturers instructions then it'll probably work just fine.
Cheers
Nick
I think from memory, that an open thermostat in a typical car probably flows about the same as a 1.5" pipe. maybe a little less. With the thermostat closed the bypass is more like a 5/8" pipe on a fitting with more like 1/2" ID so there is a substantial difference.
I was inclined to say impossible to a 4 bar difference between pump inlet and pump outlet, but I'm not a pump engineer and didn't really know. It just sounds impossible for an automotive water pump to generate 45 psig in a system with typically a 15 psig pressure vrelief valve.
Pat
for site rules
The hole in it that passes coolant is smaller than that, and has parts in the flow path that would cause some restriction.
It would have to be a big thermostat or a long pipe for the flows to be equivalent.
Since the pump is working against a restriction, and the pressure relief is downstream from the restriction, of course the actual pump head can be higher than the pressure relief setting.
Jay Maechtlen
In the case of this engine, and I think for most production car engines, the path of the cooling circuit is: pump – engine block – cylinder head – thermostat – radiator – pump.''
You forgot about the cabin. The cabin is on the engine loop also. If your pump is to be on/off - temperature controlled then you will have no heat in the cabin once the matrix is cooled by fan. I would think very hard as to where to mount said temperature sender too.
Also, I still think removing the stat id a bit daft, on some housings, they have to be there in order for the coolant to flow correctly.
First image is what I call a single plate stat, It is from a Subaru, it is a basic, 'stop the flow from housing out to hose' type
http://images2.carpartsdiscount.com/auto/archive/p...
Second Image is a Vw Mk2 Gti stat, and what I call a double plate, not only does this open the flow to the rad hose, but it also uncovers a port machined into the block and re routes coolant. If you remove a stat from a Gti it all goes a bit haywire in terms of circulation.
http://images.whisystems.com/smartpages/partinfo_r...
I cant remember exactly what happens with the two plate - unbelievably since Ive studied these engines in great depth. Perhaps Ill remember in the morning, its 5.40am here at the minute.
Check your exact coolant path out before you do anything, thats all,
Brian,
@ Pat, I just got reminded of being in a pit some time ago, the head mechanic was screaming down the phone ''We need another Craig David pump'' it was hilarious, and tense at the same time as he was paying, and a right old grump.
For its pumps Davies Craig recommends a controller.
It seems to feed the pump with a combination of pulsed and proportional driving, dependent on the operating point.
They have a very good reputation in the tuning world. I would expect nothing less than this stuff to work when fitted as per manufacturers recommendations.
I do not want to question the idea that 2 flow + 2 pressure can be replaced by 3 flow + 1 pressure. That is basically what they do as they keep the system pressure, they do not rely on any pressure bonus generated by the pump but rather rely on more flow.
But perhaps I'm over-simplifying this one
I measured the pressure just upstream of the thermostat, while the rad cap is downstream.
Nick,
I was at least as sceptic as you about this 4bar
They are real. I tested the sensor and measuring chain with compressed air to double check.
On the graph you can see I have been driving the engine till 3600rpm while warming up, then up to 5400rpm and when it was warm enough (and reached system pressure) till redline.
To know the differential pressure generated by the pump, the system pressure (0.8bar) should be subtracted.
Brian,
The thermostat in this engine is a single valve type, it does not block any bypass when it opens.
But your remark made me wonder about the actual hydraulic layout.
In the standard car setup there are 3 fixed bypasses.
A first one that heats the throttle body and a cold start air regulator thingy.
Smallest diameter in this circuit is about 5mm.
A second one that was feeding the turbo core; also around 5mm.
It is blocked off because the turbo was replaced by a supercharger.
A third and larger one supplies the cabin heater and the oil/water heat exchanger.
This bypass is connected halfway the engine almost at the rear of the block, roughly half a meter upstream of the thermostat.
During the test, the heater control was at minimum, which is really a closed tap in this case.
The heat exchanger has been ditched since years, replaced by a front mounted oil cooler, and that water path is blocked.
That was -roughly- a 10mm inside diameter hose.
Having this blocked off will be the cause of the pressure to rise that high inside the engine.
So my measurement turns out to be in no way representative for the standard situation
I will install a hose with a fixed restriction inside in order to achieve the same bypass as with the heat exchanger and then repeat the measurement.
This will not be before spring unfortunately.
Also with another ambient temperature the thermostat will not be open the same amount and this will influence the pressure, so do not expect a back to back measurement.
Anyway, there will be pressure generated by the pump and I am still wondering to which extent the designers have been counting on that when they designed the cooling system, this was basically the underlying question in my first post.
Unfortunately nobody showed up and said hey I designed the cooling for the new [brand] engine.
I’ll try my contact person inside BMW but he’s commercial so not sure if this will pay off.
The twin plate stat is better known as a bypass stat - I should have mentioned that, it was late when I wrote the last post.
Brian,
If the thermostat is removed, high pressure (probably lower than 4 BAR) will appear at the radiator cap and may push water past it.
I'm sure you have no idea how many liters/min or gpm are flowing? With an engine-driven pump and unlimited power this will be proportional to rpm up to high powers (like over 10hp) unless there is belt slip. With an electric pump this will be lower for an increased pressure head as the electric pump is power limited (very low power, like 1/4 hp).
Cavitation will lower efficiency and will erode the blades, but won't stop the pumping. The flow increase with rpm should fall off the straight-line, but may not stop rising unless it's really bad.
The pressure might go up a little bit due to increased flow through the radiator and water lines from radiator to pump, but the main effect will be that pump outlet pressure drops (in some instances possibly leading to pump cavitation). As mentioned above there are also systems where removal of the tstat will give unfettered bypass flow - in those systems I would not expect an important change in pressure at the radiator cap (and much lower pump outlet pressure).
This is not to say that electric pumps can't be powerful, but they would require the electrical system of a hybrid (especially higher voltages) to run the pump for a decent size engine. That is where I would expect to see electric pumps employed.
The drive strategy for the Craig pumps is explained in an instruction sheet on their website.
Depending on the difference between measured water temperature and setpoint, it toggles between on and off at 6V with various duty cycles or it ramps up to system voltage.
140Airpower,
As I did not log the absolute water temperature, I can only tell that it was at normal operating temperature, which is confirmed by the voltage over the temperature sensor being stable.
This is the same graph but taken into account only the data around the redline pull, but to be honnest I don't see what new insight it brings:
link to the graph
At 5°C ambient, the thermostat will not have been open completely.
Still I believe that in this case, pressure right upstream of the thermostat gives a good figure of the water flow as it is proportional to it.
Just as Mike also pointed out, you are right that with the thermostat removed the radiator will be the next restriction in line and obviously it will get pump induced pressure in its inlet tank.
BMW seems to use electric pumps on some engines:
Link
but I have no feedback from that side yet.
BMW seems to have reduced the required power a lot. They do use an electric pump. I would like to know more about their cooling system.
The CA18DET has high resistance with the thermostat in. I wonder what it would be without the thermostat.
"Schiefgehen will, was schiefgehen kann" - das Murphygesetz
I assumed that for the CA18DET, because of the high pressure, I thought the Tstat being closed stopped or severely restricted the flow like scenario 1. At the left side of the graph were you can see two populations of points, one at a higher pressure than the other, I guessed that was showing the action of the Tstat. However, I'm not familiar with cooling system of that engine.
Pat
for site rules
All the cars' thermostats Ive seen have been the dribbling "bypass" kind at the stat...but I think many had a pencil-sized bypass somewhere in/near the stat housing to allow a bit more flow thru the block.
Pat
for site rules
Pat
for site rules
These details are interesting when considering the power requirement of the water pump and converting to electric drive.
I would recommend taking a look at this book from SAE: http://books.sae.org/book-sp-1541/
Also, it may well be worth downloading this free software with which you can model your system and perhaps use it to point you in the right direction: http://www.aft.com/psim
If you try it, let us know how you get on.
PJGD
Factory Manuals in the 50s and 60s show and describe specific circuits provided for continuous circulation in addition to the heater circuit (which was sometimes optional in those days) .
From 1958 (Ford) Edsel shop manual, 261-332 V8 engine cooling system description.
"If it (the thermostat) is closed a small portion of the coolant is returned to the water pump for recirculation.
In the 6 cylinder engine cooling system description the Edsel manual is more specific - "a small portion of the coolant is bypassed thru a pipe which returns the coolant to the water pump for recirculation. "
I'd bet there still are still such circuits today.
Uniform cooling would seem impossible if relying on conductive or thermosiphon heating of the thermostat.
The Slant 6 diagram implies the small bypass flow is through the block.
The bypass as I understand it is to:-
1) Provide water heated by the block and head to the thermostat heat sensitive side to cause it to open as the coolant in the head and block reach operating temperatures.
2) To provide water to the pump so it does not run in a permanent stall or state of cavitation which might damage the vanes through cavitation or damage the seals/bearings through overheating and lack of lubrication.
Pat
for site rules
Even wihout the thermostat the electric radiator fan or a thermostatic mechanical fan act as a fairly effective pseudo thermostat.
A consequence of this, apart from effect on fuel, ignition, and other parameters (such as idle speed), is an increased tendency for sludge formation in the oil. Higher fuel consumption is predicted also, both due to operating parameters, as well as higher oil viscosity, and higher heat rejection to the coolant. As you say, in tropical Oz, these may not be significant issues.
The tropical climate makes the warm up time relatively short compared to cold climate, but still extended compared to with the thermostat installed. I guess if the typical trip is also long the % extra time spent at lower than optimal temperatures becomes small, but still why extend it at all.
Pat
for site rules
As above, the only negative effect of removing the thermostat is a longer warm up time.
The benefit of removing the thermostat for an electric pump is the reduction in total system resistance and the power requirement for a given amount of flow. IMHO for a small engine, like the CA18DET, this is a much more interesting option than for a big SBC or LS.
"Most of the cars I own are older than 10 years (one is 23)."
Do any of the 'stat-less ones have aluminum cylinder heads, and are any SAABs or Subaruooos, or use Mitsubishi 2.6 engines?
Dan T
To explain further on my views on thermostat-less engines: Obviously I don't recommend removing the thermostat on new cars or even newish cars, or in cold areas etc. - especially if they are still under warranty. I was assuming that jcd06 (or his mate) has modified his CA18DET and was probably having overheating problems especially seeing it is a turbo engine. I think removing the thermostat does help any marginal overheating problems. If the CA etc. engine has been modified I doubt if the owner is worried too much about marginal increases in fuel economy, engine wear etc. after start-up.
I don't know for sure, but I doubt if V8 Supercars, Nascars (or just about any competition engines) use thermostats.
I think thermostats are very rare creatures north of the tropic of capricorn in Oz.
- 4 and 5 cylinder Volvos seem better than most at keeping headgaskets intact on aluminum headed engines way past 100 kmiles.
I suspect that their scheme of forced recirculation, with a double disk t-stat that actively controls the flow thru the bypass circuit may have something to do with both characteristics.
