Hi, I`m designing a bracket for
I`m designing a bracket for pipe at high temperature. The bracket consists in austenitic stainless steels plates welded together. Ansys is the software that i`m using for stress analysis.
Which code? should I follow to determine the stress limits (allowable stress) for comparison?. Only loads and pressure are used for the analysis in ANSYS
I know that creep will influence my stress limits because of the high temperature of the pipe (1350ºF).
Any suggestions???
Any suggestions???
RE: Hi, I`m designing a bracket for
