Thermal contact coefficient
Hi all,
I'm looking for thermal contact coefficients for Al2024-T351 / Ti-6Al-4V interface, Al2024-T351 / Steel interface and Ti-6Al-4V / Steel interface, varying with applied pressure.
I looked in ASM, NACA, MIL-HDBK, various heat transfer handbooks but I could not find reliable information. Graphs found in the internet are all very different, and provided information is absolutely not in accordance.
Do you have any idea where I could find such information? Even if materials should not be the same, for a start it would be enough to have thermal contact coefficients for Al / Ti interface, Al / Steel and Ti / Steel.
Thanks in advance.
Cheers,
Alberto
RE: Thermal contact coefficient
Alberto,
In Heat Transfer by J.P. Holman (McGraw-Hill) 4th Ed., there is a table 2-1 showing data for some metals as function of roughness, temperature and pressure. The chapter2-10 explains the reasons for the scarcity of reliable data. It also brings a worked out example.
Suerte.
