"Miniature" needle roller cage assembly?
Hi all, I'm looking for a bearing that I can't seem to find and was wondering if I'm missing something. The bearing is a needle roller cage assembly for 1/4" shaft and 1/4" long. It seems all the big bearing manufacturers start the cage assemblies for 3/8" shafts. I was thinking that what I have may be a drawn cup style where the cup was removed however when I bought one like that and removed the cup the bearings fell out of the cage. On the original they seem to be captive in the cage. Is something like this a specialty bearing or should I be searching for some other keywords I'm not aware of?
Thanks for any help.
RE: "Miniature" needle roller cage assembly?
Thanks guys but again those are for drawn cup style. I need just the cage assembly.
Thanks guys. I found what I needed!
