Joint Efficiency Factor for 46 year old oil pipeline
Hi all,
To derate the 46 year old pipeline, what joint efficiency factor to be used ( any refence) or not to reduce the factor and calculate based on wall thickness.
10815L
RE: Joint Efficiency Factor for 46 year old oil pipeline
I think a new pipe is in order??
What kind of pipe, steel, iron, concrete? Material specification? How was it stuck together? Gas flame, welded, glued?
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
its oil tarnsfer pipeline, material is CS (carbon steel) specification "API 5L GrB". due corrosion we would like to derate it for future use.the remaining thickness is 0.13 inches. is this ok if i use 0.9 or .85 joint efficiency factor in Barlow's equation for the safe operation conditions (extra safety factor), please advise me.
Why not leave that at 1.0? It is a function of the pipe weld type. Take your safety factor by increasing the metal loss some more, because "The reduction in strength was estimated by considering average general metal loss with an added saftey margin of X inches subtracted in lieu of calculating remaining strength based on actual measurements of maximum corrosion pit depths and group patterns."
