FBD for taper roller bearing
Hi all,
Can someone help me in drawing the free body diagram for a taper roller bearing when a radial load is applied on it. FBD for the inner race, rollers as well as the outer race separately . Any good material on this also will help me a lot.
RE: FBD for taper roller bearing
Thanks for the quick response .But i am looking for a readily available material which is available on net .
