Horizontal moving load
Hi, all
I am designing a warehouse with overhead crane.
I want to add the loads from the crane as moving loads with influence lines. The problem is that I can't see option to add horizontal forces in the vehicle definition, nor in the load case definition. Is there any option to define horizontal vehicle loads?
Thanks in advance!
RE: Horizontal moving load
I am not so sure about this, I would suggest you to apply the horizontal loads at the worst locations(maybe more than one) as independent load patterns and then create an envelope to get the overall effect.
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
Well that's the most obvious way. I figured it out myself.
I was just wondering, why there is no function to make influence lines for horizontal forces in SAP2000.
Dear dgerashki,
As you could see, I asked this question also. But I think it could be possible if you try next: you can rotate local axes of the crane beam, and then try to apply the load. I don't know if it works or not.
jJ
It does not work. The moving load is always vertical. Event if it worked, it doesn't solve my issue. I want to add simultaneous vertical and horizontal forces from the crane in the building and get an envelope of the acting forces.
I found another solution. I loaded every frame with vertical and horizontal forces - different load case for every loaded portal frame and then made an envelope combination from these load cases. In this case every position of the crane in the building is considered.
