Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...What a great service! This is the best site I've ever seen!!! It totally restores my faith in humanity when people take time out to help other people..."
Geography
gravitate (Mechanical)
17 Jan 13 3:06
In the nuclear industry how is it possible to seal a pipework (cooling water) through a concrete penetration. I am a bit confused to how you can seal it yet bear no loads on the concrete.
I havent seen this in practice while I have been on site (well not paid attention to it anyway). Could someone please explain how this is done.
I take it in the design you have to put in supports to ensure no loads are put on the penetration.
Helpful Member!  C2it (Petroleum)
17 Jan 13 3:51
You want to seal against what ? If it's just a weather seal then an elastomeric sealant will do the job with no significant loads, provided the pipe is properly supported and restrained.
If you are dealing with a pressure barrier, a Bestobell type seal might do the job, for low pressure only. If you are a sealing a containment against CO2 pressure or similar, I would suggest there will always be load transferred to the penetration, and any method that purports not to do so will be a math fix only.
17 Jan 13 4:44
Hi thanks for the reply and information. I found a Bestoble seal in google thanks. What do you mean by a math seal though please? Is this where the thermal shield of the pipework is welded to an embedment in the concrete?
C2it (Petroleum)
17 Jan 13 6:41
I was referring to the all too common situation where a calculation shows zero loads, which cannot really exist. A mathematical fix, usually involving restraints that cannot actually be built, but exist as a zero in a stress calc input field.
17 Jan 13 6:49
AHA nice. Thanks for that.
Helpful Member!  bimr (Civil/Environmental)
17 Jan 13 10:33
A metal liner with metal expansion bellow is commonly used. Should not transfer significant loads to the concrete. See the attachment and link.
http://www.power-technology.com/contractors/expans...
Helpful Member!(2)  nackra (Civil/Environmental)
17 Jan 13 11:33
http://www.linkseal.com/
another variation to bimr's good suggestion
Close Box
Join Eng-Tips® Today!
Join Us             Close
