PCB Mounted Pressure Sensor
I am having a problem with this pressure sensor.
http://cache.freescale.com/files/sensors/doc/data_...
The sensor is glued into a hole that goes to the gas under test. The gas is leaking however so I am looking for a threaded sensor as similiar as possible. I am not an EE and haven't dealt much with boards, but does such a sensor exist, or am I asking something similiar to how I can weld steel to aluminum(in an average welding shop)?
RE: PCB Mounted Pressure Sensor
The reason I suggest this over a threaded arrangement is that ultimately I think you want to solder the sensor to a PCB. If the sensor is threaded you have to worry about the whole assembly rotating during manufacture/repair. Could be a hassle.
