End-Plate Web Weld
End-Plate Web Weld
Hello all,
Are there any limitations to weld thickness for fillet welds placed on two sides of a beam web for a end-plate moment connection? I haven't been able to find anything and we are joining AISC to get the Design Guides to verify the connection software that we are using. Currently the program is requiring 5/16" fillet welds on each side of a 0.3" web to develop web forces into the columns. Any thoughts? As a disclaimer, this is a preliminary design and I will have the proper literature in house before this design is finalized.
RE: End-Plate Web Weld
I think the idea is that (for seismic applications) you expect the flanges to go past yield as your moment approaches Cpr*Ry*Mp. Therefore, you don't want any fracture to occur at the web weld.
For non-seismic applications you may be justified in ignoring this provision. After all, it's not included in Design Guide 16.
www.FerrellEngineering.com
Providing fabrication and erection efficient structural design of connections. Consulting services for structural welding and bolting.
http://www.webcivil.com/uswelding.aspx
A more common weld size would be 1/4" which would seem to be adequate to develop the yield strength of a 0.3" web having Fy of 50 ksi.
BA
