51N Relay Settings for Unigrounded Systems Feeding Delta Connected Loads
I'm trying to find some further reference material on determining the ground relay settings for a 3 wire solidly grounded system that feeds delta connected loads. (i.e. sub-transmission feeders with Dy1 power transformers) What situations would cause sympathetic trips to occur if the ground settings were set too low other than accuracy of the CT's & relay?
Thanks!
Thanks!
RE: 51N Relay Settings for Unigrounded Systems Feeding Delta Connected Loads
