Minimum Pressure Required to open a spring loaded Check Valve
Dear All,
I would like to know what is the minimum pressure required to open a spring loaded check valve.
Thanks in advance...
RE: Minimum Pressure Required to open a spring loaded Check Valve
Very little, depending on valve type, construction, area and spring characteristic and orientation in piping system (plus of course pressure behind (downstream) the valve and any local resistance/sticking9.
Any reliable valve constructions/brands will have datasheets published giving general information on minimum pressure to overcome spring pressure. For low pressure systems, for instance biogas collected from different waste products, opening resistance and pressure loss could be significantthis.
If you have a particular problem: please give us all details, as there usually is a 'common practise' for optimum choice of valvetypes and 'sensible brands' depending on application.
Good luck,
Latexman
The manufacturing of springs is not a very precise mode without having any other method of adjustment in the valve itself.
gerhardl is right, there are many factors that count like disk surface, closing pressure, seat area geometry, etc.
